Hi
I have a 2002 50HP Johnson 4-stroke (DF50 Suzie) that has a leak down problem. I have replaced the o'rings and seal and that hasn't helped. Could the problem be a bad down pressure valve? This is the Showa system and I am a long way from parts as I have to order everything, so would like to solve the problem as the O'ring kit didn't.
Thank you; Wayne
Thank you; Wayne
