Re: Another printing question
Nope...one router should do it.
Can you reach the Web with the laptop??
Does the desktop computer run XP Pro or Home version?
On Laptop computer"
Click Start
Click Run
Enter "CMD" (no quotes)
Click OK
At prompt, type ipconfig /all
Hit Enter key
Write down IP address of your computer's network connection
(example: 192.168.1.101)
Do the above steps on desktop computer, write down IP address for the desktop computer.
On laptop:
Click Start
Click Run
Click OK
At prompt, type ping (ip address of desktop computer)
example: ping 192.168.1.100
Do you get a timeout blurb?? or a good ping response?
Try pinging the router:
At prompt, type ping (IP of router)
Example: ping 192.168.1.1
On Desktop computer:
On desktop computer:
Click Start
Click Run
Click OK
At prompt, type ping (ip address of laptop computer)
All this confirms that each computer is connected to the router, has a valid IP address from the router, and can 'see' the other computer and router.
The above examples assumes that the routers IP address is 192.168.1.1 and has DHCP enabled and issues IP addresses starting at 192.168.1.100. Your router , depending on make/ model may have a different base IP address (i.e. 192.168.0.1 etc)
