Re: another question for the wiz
Robert 4:45PM, just got online after some glasswerk....If it has no fuse in it, you need to put one in it. Unprotected circuits can literally catch fire, (which is un-good).
<br />And the advise Yepblaze gave you about disconnecting in turn,to find it,is the best way. Another is with a volt/ohmeter. They are not hard to learn how to use,come with complete instructions, and a cheap one can be purchased for 12-15bukz. I keep a cheap one on the boat under the seat at all times.<br />You would disconnect both ends of the wire,and hook the ohmeter up to one end and to engine ground. If you have continuity, it is shorted to ground...Unless it IS a ground wire (this is where the good ol shop manual comes-in).<br />Good luck.
