Quick backstory – 2001 VP, 7.4L Gi PEFS, Where I store it, they drain the oil, change the filter when they winterize the block in Oct and then add the fresh oil in the spring. This last Saturday, load up with fresh oil (15W/50 Syn) – 5 quarts. I tend to work with the owner (friend) he poured the 5 quarts in, started on muffs, checked everything, launched – test run, oil pressure good, holds temp on a plane (all good). Bring it across the lake to slip. In the past I have had to add a quart to keep it in the safe range (6 total). I pretty much check the dipstick every time I go out. Check it this time and it was way past full! I know these dipsticks can be finicky, so I warm up the engine let it sit 10 minutes check it again still high. Tried letting it sit overnight, no change.
Went back, warmed up and sucked out 2 quarts and let sit 10 minutes checked it, and it was back in the safe range. So I am wondering last fall if the boat wasn’t level or the pump lost prime could there have been 3 quarts or so still in there? Prior to pouring the new oil in the dipstick showed dry. Thinking of doing a complete change to start fresh. Could there be anything else I am missing? Thanks.
