Another Question regarding 1958 Johnson 35 hp
The320
Took it out for about 3 hours this morning, fired up great, and ran great. Did alot of fishing and docked it for a few minutes. Started it back up and it seemed to be miss firing, then as i went along at a higher rpm, it smoothed out, no more miss fire. Then it seemed as though it was slipping the gear to go forward, but reverse was ok. Forward gear would engaged but at a higher rpm. Any thoughts on where to start???
tashasdaddy
Re: Another Question regarding 1958 Johnson 35 hp
any thump or bang like hitting a log? or is it like the prop is slipping?
The320
No, at first I thought the coils needed to be charged. But now it sounds like a gear is slipping and then as I get to a high enough rpm, it slams into forward gear and takes off. Could my lower end fluid be low and what type do I need?:confused:
wilde1j
Most likely: clutch dog and fwd gear need to be replaced. Less likely: an adjustment to the shift cable. If nothing has been messed with, parts are probably needed, which require disassembly of the LU.
samo_ott
Clutch dog. But the LU's on the '58 35 are easy to take off and apart.
The320
Well, looks like i'm gonna have to pull it out of the water. Any one know where I can find these parts? Also, is there a diagram of what I'm getting myself into anywhere on the web? Don't have a manuel.
tashasdaddy
try http://www.tcoutboard.com/, i sold a great 58 35 powerhead, bad clutch dog, bought another lower, and the dog was bad in it also. tcoutboard, were selling lowers for that motor for around $200. guaranteed.
The320
Well, tightened the shift cable a little, felt like it got a little loose and it's all good now. For now I should say. Looks like its something I'm gonna have to keep my eye on.
