imported_boatrookie
- Joined
- Nov 10, 2006
- 51
I have a 87 mercury 50 HP classic fifty on my 87 basstracker. I just bought it last month and i could not get water to pump out the, I believe you call it a tell-tale pipe. I removed the lower unit and took the cover off the water pump and replaced the impeller and the two gaskets with the metal one in between. I fallowed the manual on how to do it. before we put the lower unit back together i tried blowing low PSI of air through pipe that takes the water to the top end, and it sounds like it is leaking at the top where it connects to the top end. Is there supposed to be a grommet or something on the end of the water pipe where it slides into the pump, cause the kit i got from the local parts guy didn't have one. I also tried blowing and sucking air with my mouth through the tell-tale tip, on the side of the engine and it seems plugged tight, is it supposed to be like that. we put the lower unit back together and hooked up the muffs to it and ran it. still no water out of the tell-tale, just a drip. the water blows out the propeller.
Can you please help me solve this problem. I don't want to take it to shop just fiend out it was something simple but costly.
