manny91979
- Joined
- Apr 15, 2010
- 49
Hello all,
I have a 1971 Evinrude 50 Selectric model # 50173s. I have the very popular "no reverse" and its evil twin brother the "intermittent reverse/neutral" problem and through the info I have obtained in this forum through much searching I have narrowed the problem down to the selector switch. My plan is to take the switch apart and clean the contacts and see if that helps. So here is my question:
What mechanism does the selectric system use to ensure that reverse is not engaged at full throttle? I ask because I disassembled the control box and don't see any physical obstruction on the switch portion that would stop one from pushing the reverse button while underway in forward. My best guess would be that somehow the switch can sense RPM and not send the 12v signal to the corresponding solenoid. I am curious about this because I want to make sure that if there is some type of system, electrical or mechanical, I want to rule it out as a possible cause for my issue. For example, if it is tied to RPM, perhaps my idle is set too high for the switch to operate. P.S....yes my idle is set correctly, just using that as an example.
