shiloh87
- Joined
- May 9, 2021
- 65
Hello all, just jointed up, great forum, lots of information here.
I`m having issues getting my stern drive to shift, a little back story first.
Started a boat project 2yrs ago and decided to build a deepV16(donzi sweet 16ish) cold molded plywood/mahogany and cedar, epoxy glassed, the boat is now finished.
Bought a donor boat for the running gear, 1984 470, and stern drive Alpha1 I believe, eng#6684502, drive#6683465. The engine was seized at 165hrs, but being a bit of a motor-head, I did a ground up rebuild this past winter, all done and purrs like a kitten. The stern drive needed a good cleaning paint and decals, impeller, also rebuilt the power trim system, all good.
The problem I`m having is, all I can get from the shifter is forward 12:00, neutral at 11:00 and no reverse (moving the shift shaft by hand) Stern drive is installed, cables disconnected at the engine.
Was in forward when I installed the LU, prop locked in forward (prop rotates CW when in forward) could the lower shift shaft be off by a spline or is the lower pooched (fingers crossed)
The thing is when the LU was on the bench I could shift it, forward neutral and reverse??
I know this has been asked a gazillion times, but I`m befuddled at this point.
Cheers
Cheers
