basscat348
- Joined
- Jan 5, 2010
- 54
I have a non electric shift mid 80's johnson 140 just guessing because im not really sure what year it is ,anyways with the lower unit out and manually spinning the prop shaft should I be able find a forward, reverse and neutral ? I can only make it go into gear by pushing all the way down on the shift shaft,is this the way its supposed to be ?Other lower units I have worked on I could easily find forward,reverse and neutral.I have 2 units here that do the exact same thing,will only go into gear by pushing all the way down on the shift shaft.Also when it does go into gear it locks in both directions is this normal?Usually I have seen it will only lock into 1 direction and be free in the other.
