Another Stringer Question
Blackstorm
I have the Tri Hull cleaned up on my 77 MFG Gypsy now the question is the original stringers stopped any water that got into the hull from getting to the bilge.
1. Is there a way to create gaps or holes at the bottem of the stringers to allow water to pass? or is there another solution. I hate to do all this work and then have to do it again in a couple of years.
2. Does the bilge well have to have vertical wall or can they be sloped. I am goning to have to create a new bilge well and I am trying to avoid 90 degree angles and I am thinking 65-70 degrees and the fiberglass should have no problem making this type of bend.
thanks
Glynn
