CamaroMan
- Joined
- Mar 18, 2016
- 330
Trying to free a motor thats stuck. Pumped a cocktail of Atf/Acetone 50/50 into cylinders yesterday. Removed crank pulley and will try fab up a bar to screw into damper -
whats the possibility something in the back it that stuck? If i could move the prop a hair in gear wd that eliminate an outdrive issue? Whats different between removing an omc outdrive than merc?
thanks - any tips welcome!
