I successfully replaced my impeller and associated parts last night. I was mostly worried about the shaft being seized, but it came off no problems at all. You just never know if the last owner performed regular service or not.<br /><br />My old impeller didn't look that bad:<br /><br />
<br /><br />...but I replaced it anyway:<br /><br />
<br /><br />The gear lube looked to be in good shape. The previous owner told me he replaced it recently, and I would say he did. Neither of the gearcase plugs had rubber o-rings on them and I want to make sure I put it back like it is suppose to be. The impeller kit came with a couple of pieces that appear to be about the right size to go over the plugs, but look like they are made out of gasket material, not rubber.<br /><br />Are these what I am suppose to use on the plug screws, or should I pick up a couple of rubber o-rings from my local Merc dealer?
