mannixconnors
- Joined
- Jun 28, 2010
- 19
I am having an issue with the water flow. I have a 40 hp 1982 two stroke. I replaced the water pump impeller but still do not get a full strong water from the pee hole it just kind of dribbles out at idle and gets a little stronger at higher RPM but the water is cold. I took off the lower unit and blew air through the water tube and could feel the thermostat open and I got good air flow out the pee hole.
Once I shut the engine off I got a steady stream of warm water coming out of the center of the prop. Is this normal or do I have a problem?
I did make sure that when I put the lower unit back on that the tube was in the water pump housing.
I am really concerned as I do not want to blow the engine up and am leaving for vacation with the boat Friday. Can anyone please help?!?!
