I have an late sixties 16' Lynn Craft. The transom has a slight bit of flex in it when I put the motor up and push down on it. I drilled some holes today to check and see if there was moisture and the shavings came out dark and wet. So I know there is moisture in the transom.
I am thinking of having a stainless bracket made that would be like a motor bracket and spread the load over the transom, and I plan on bolting thru both sides to add strength.There are no cracks in the fiberglass. The motor is a earl sixties Mercury 50hp.
I plan on only having the boat for another year or so. Is this a safe and decent idea.
