Another What Volvo Outdrive Is This Thread...? Pics Inside......
jw2000uk
Hi lads.... Ive browsed and browsed...
But theres such slight differences between legs..
And from UK shops ive had mixed answers..
Can someone shed some light on this..
(Its been painted ;-)
Don S
Re: Another What Volvo Outdrive Is This Thread...? Pics Inside......
Looks like a 280 lower, the upper looks like a combination of several different drives.
It is not all original. Some of the things like the tilt pivot pins look like bolts.
mohavafish
That looks just like my 275 on my bayliner capri
f_inscreenname
Looks like a 280 with the exhaust
jw2000uk
Thanks for the input guys..
So if i aim for 275/280 anodes.. I shouldnt go far wrong?
Also, will this fill through a dipstick fir the gearcase oil? Or can i pump through lower bolt?
Cheers.
f_inscreenname
Cheers.
Pump up through a screw in plug in the bottom
jw2000uk
K, thanks for the input...
Just one thing. How do i know when its full, as usually u pump untill it comes out of the top screw? Cant see a top screw..
jerryjerry05
Where the shifter linkage isThe first pics shows it an allenhead screw about 5/16 allenhead.That's where you fill it.Looks like a 280 with a few parts from a 275.
Zincs from a 280 will work.J
f_inscreenname
Should be straight 40 weight oil
PiratePast40
Sorry but the above picture is a tough way to perform a simple task. I think you're getting this one confused with a Merc drive. On the Volvo outdrives of this era, it's a straight through shot so you don't need to pump it in from the bottom. Fill from the allen head screw above the shift shoe cover. Remove the dipstick for a vent path. Use the same type of motor oil as the engine. 10W-30 works fine. New o-rings for both are a good idea.
It's cheap insurance to do pressure and vacuum tests as well so you cut down on the number of surprises. A manual will really help you out.
