Hey guys, I am in a situation where I could use your advice. I bought a 1996 lund tyee 1950 magnum gransport with some transom damage and no motor. I am in the process of fixing the transom and I bought a 1999 mercury optimax 150 to power the old girl. The opti had a brand new factory powerhead installed in 2011 by a certified merc technician and has only 30 hours since the rebuild (the guy went up to a 225). With that known, I don't think it will have any age related power loss. I have looked at Mercury's prop calculator and it 's telling me that I should get something like a 16x 16p in a three blade aluminum or a 14.5x 17p four blade prop. A friend of mine is telling me that he doesn't think that is enough prop. So tell me what you guys think.
Specs :
Boat :
-1996 lund tyee 1950 magnum gransport
-weight : 1650 lbs
-length : 19' 8"
-beam : 90"
-fuel : 60 gallons (full)
Engine :
-1999 mercury optimax
- hp : 150
-weight : 432 lbs (dry)
-rpm : 5425
I would guess that most of the use will be for fishing with 2 guys, but I will be taking the kids out tubing from time to time. Fishing will be mostly walleye, but we go out to lakes superior and Michigan salmon fishing probably 4-5 times a year. Your advice is greatly appreciated. Thanks - Nathan
Specs :
Boat :
-weight : 1650 lbs
-length : 19' 8"
-beam : 90"
Engine :
- hp : 150
-rpm : 5425
