boatingnva
- Joined
- Aug 24, 2006
- 34
Sorry, another winterizing question. I've gone through all the stickies, searched here high and low, and even gone through the Merc service manual (which isnt exactly very clear), but I'm still not clear on which hoses to pull to pour a/f into. The attached pic is of a Merc 5.0 exactly like mine (20' Bayliner, 5.0 Merc, Alpha 1). At the top of the engine there are 4 hoses coming into the thermostat housing. My questions are, a) do all 4 need to be pulled and a/f poured into (leaving the plugs out until the a/f color is consistent), and b) will this get a/f into the engine block area sufficiently or do I also have to pull the thermostat and pour a/f in through there?
I know air doesnt freeeze, but I would feel better if it had a/f in it.
I've already pulled the manifold drain plugs, wired them out, etc, changed fluid in lower drive, topped off tank with 1.5 cans of SeaFoam. Now just need to warm it up on muffs, fogg it, change oil/filter/fuel filter, and do the antifreeze part.
Thanks
Thanks
