2broke4this
- Joined
- Dec 13, 2006
- 103
I found a boat on craigslist a while back and brought it home with me... I did almost everything wrong (bought it on a cold day, no sea trial, didn't even hear it run). It's a 1986 Ebko Biarritz 210SS. The hull is in nearly perfect condition and the boat has barely been used (158 hours)... the engine and outdrive are beautiful... the interior was pretty rough, but I knew that and was okay with it. I walked around inside the boat, and with the exception of one small area, it all seemed solid. That was because the water-logged wood was all frozen! Many of you are probably already shaking your heads, and I don't blame you.... what follows are some pictures of the fun I've been having! I'm starting to think I should have kept the old boat....
See the pretty hull?
Here's the engine... (much bigger than the 3.0 that was in the old boat)
Here comes the fun part.....
An example of the seating conditions...
Started pulling the vinyl out...
Let's see what's under the carpet... maybe this was a mistake! The board is covering a hole, so we don't fall through!
It's not pretty...
Got most of the floor out before we called it a day...
The foam is waterlogged and has to go...
Still have more to pull out....
I've been reading lots of threads about the work I've got ahead of me, and I'm not excited about it, but I have an image of the boat out on the water... so that's been keeping me going! I'd love to hear any comments/suggestions that you all may have!
It's not pretty...
