Two questions.
I bought a 1983 EZLoader trailer for a 1994 16' aluminum Lund Rebel. I am going to replace the unserviceable trailer springs. I'll inspect the axle and replace the u-bolts, of course. The trailer is intended for a 16' boat at about 2,000 lbs gross. I estimate that trailer, Lund, motor(s), batteries, and other stuff will never be over 1,250 lbs. Trailer has rollers, not bunks. Boat is 72" wide. Trailer frame is 60" wide, 73" at hub faces. I assume that using a trailer that is larger than needed for the load will only cost me a little extra fuel. Every other aluminum boat carrying trailer I ever owned had bunks. Springs are 26" open eye, "C-hook" type. Fishing trips are frequently 150+ miles one way, and over poorly maintained roads.
I don't want to beat the boat to pieces with an overly stiff set of springs.
Should I bother with lighter springs, or buy the standard "2,000 lbs per pair" leaf springs? Should I even worry about it with a lightweight Lund? Lightest I can find online is a 2-leaf set at 1,600 lbs per pair.
Second, is there any problem with using rollers with an aluminum hull boat? I've seen reference to possible "dimpling" of the hull metal. This Lund is no beauty queen, but not trashed, either. Should I even worry about it?
I RTFM, and could not find specific answers in the forum.
Thanks for your advice.
