Woodnaut
- Joined
- Jul 4, 2007
- 634
So I forgot to lower the antenna before I went under the railroad tressel, again :facepalm:, and ended up cracking the antenna right at the base. The following photo shows part of the crack and how I have extracted it from the SST base.
Visual inspection of the antenna reveals no damage except for the very bottom. All of the damage seems to be confined to the last 2-1/2", so I plan on cutting off the bottom 3" and reinstalling it in the base. I'm hoping that no serious problems exist because this apparently does not encroach on any of the antenna internals - there is just coax cable running through this part of the antenna. The coax was not pulled so I'm still hoping there hasn't been any internal damage.
I realize that antenna repair can be a dodgy affair, but I'm hoping I can get away with this one without any deterioration in performance. I guess a radio check will help to sort that one out.
What would be a good material to pot the fiberglass (antenna) back into the original SST base it was built with? Epoxy? 5200? The original material looks somewhat like 5200. Thanks for your comments.
