NascarNHIS
- Joined
- Jul 16, 2007
- 23
Mercruiser MCM 170, 3.7 L, 224 cubic inch inline 4-cylinder. Alpha 1 stern outdrive
I have read this is a classic problem with these motors most often caused by, Cam Seal at water circulator pump and would need the seals and possibly Speedy seal on the crankshaft. My question is I did a 17psi leak test that sometimes holds pressure and occasionally fails/leaks down. I pulled the plugs and they all look good a brow/gray color. I did not find any liquid in the cylinders. I did a compression test and found 150, 140, 90,100 psi. That is what concerned me.
Before I tear down the motor and replace the head gasket can someone tell me the odds of it possibly being that AF is coming from the head gasket or do I have both head gasket and cam seal issues? (I know it could be cracked block or head but I’m trying to stay positive). I am not overly concerned about the exhaust elbow gasket or exhaust manifold or gasket because I will change them if I do the head gasket.
Note. - it is defiantly AF in the oil not fresh water (could possibly be a mix but defiantly has AF in the oil).
Also this may sound silly but I cannot find the weep hole on the starboard side coolant circulator pump. Does anyone have a picture or explication of where on the pump the weep hole is located?
Bottom line is a failed leak down tests and failed compression test indicate a head gasket issue. I may also possibly have cam seal issue or should I still be concerned about exhaust manifold.
Thanks in advance.
Thanks in advance.
