Antifreeze leaking from water pump
harrisg
Volvo Penta AQ125A/270... Antifreeze is leaking from my closed system and I've traced it to the water pump. I don't hear any noise or anything else. I will change the water pump gasket but is there anything else that could be causing this or that I should look for?
Laddies
Banned
Re: Antifreeze leaking from water pump
If it's coming out near the shaft it's probably the shaft seal
harrisg
Please, can I get more info on the shaft seal you mention. The Seloc manual only shows how to take off the circulating pump and nothing more. <br /><br />Is the shaft seal an easy repair or do you have to have special tools to replace it? <br /><br />If it's not too difficult, what is the procedure? <br /><br />Do you know the part number for the seal? <br /><br />Is this the most likely problem causing this leak or might there be others?
Eggkr8
Harris<br /><br />The shaft seal is part of the water pump assembly usually. It is like an o-ring that goes between the spinning shaft of the water pump and the water pump body (casting)<br /><br />If you are leaking from the center of the water pump, it is that seal. If you are leaking from the edges, then it is gasket.<br /><br />For the amount of work to get the water pump off, I would just replace it with a new one for piece of mind and confidence. <br /><br />I got a new water pump for mine really cheap from NAPA Auto. They also sell marine parts<br /><br />good luck and remember to torque it back on properly or you could end up with a cracked water pump
Scaaty
If you run that auto pump in salt water, it will eat it up in no time. Get a pump with Stainless backing plate, ceramic seals, SS or cast impeller
jetq36s
I am sure he said it was a closed system and was circulating anti-freeze, not seawater.
Eggkr8
Who mentioned an auto pump? I said that NAPA Auto carried marine parts and that I got my Marine water pump at NAPA<br /><br />cheers<br />e
Scaaty
Whoops...closed system..., and the way that was worded at Napa wasn't clear. And it also don't hurt to mention it. Lots of people read these post. :D
