imported_wildcat
- Joined
- Jul 20, 2004
- 74
I am a newbie with a 5.0L V8 with dry joint exhaust manifold with no risers. I have the single point drain system that I will use to get water out. I then want to pour antifreeze into the 3 hoses that I have connected to thermostat. The one hose goes to the water pump. The other two hoses go to the bottom of the exhaust manifold. <br /><br />My question is that if I pour antifreeze into the two hoses to the exhaust manifold that the antifreeze will drain up through the risers and out the exhaust ducts to the prop and not have the potential to find a way down into the cylinders. It is my understanding that the antifreeze will not mix with the engine exhaust until it is at a point below where gravity will allow it back into the cylinders.<br /><br />Please help another newbie.
