Celebrity240
- Joined
- Mar 26, 2009
- 33
I got a '94 Chris Craft Concept, with only the transom assy, and it is supposed to be a King Cobra 454 7.4.
I just found a 1988 460 King Cobra.
1988 and 1994 should be the same correct? I dont think there was a generation change?
Would I be able to use the '94 transom assembly that's on there right now with the '88 motor? If yes, is the drive going to be the same generation as the '94 drive or older version? (i know the gear ratio will have to be different since its a 460 and not 454), but any other big differences?
Is the block exacly the same? Placement of the manifolds and the engine mounts??
Thanks for all the help, I was a Merc guy, this is my first OMC!!
