Re: Any experience with Suncruiser SD194 or SD190
Hey thanks for the feedback. You are the only one that I know of with previous experience. Two questions if you don't mind.
1. how stable is it when people move left to right, does it lean to one side alot if people are distributed properly?
2. how does it go over waves, does it cut through them fairly well or ride up and slam dowm on them? I have a larson fiberglass 15' and a 24' pontoon boat. I am after closer to the larson than the pontoon boat when it comes to turning and going through waves.
3. how well does it turn and can you pull tubes using the tow bar?
4. isn't the hull guaranteed for the life of the boat? Will Lowe repair it?
OK that was way more than 2 questions. Sorry about that.
1. My experience is that it tends to list to Port if not properly distributed, which I try to distribute the weight as evenly as possible.
2. Cuts through the waves fine, no slamming if you keep a watchfull eye on the waves.
3. Turning and pulling tubes are fine.
4. NO, According to Lowe's there was a 10 year limited warranty on the Hull for the 2002's if you were the original owner. I am the third owner and Lowe hasn't done anything for, even after repeated plea's for assistance.
This Winter I am replacing the Vinyl, Carpeting, fuel hoses, and Live Well line.
I will reach out to Lowe one more time when I get the deck removed to see if their is any structural fatigue that needs to be repaired.
We love the boat, just not the issues.
If I had to do it all over again, I would have purchased a Mariah. I had a 185 as my first boat and had NO issues with it at all. The reason we sold it, we wanted a larger boat.
If you still looking at the Lowe Deck Boat, go with the 22', the 19' is too small and make sure you get a 4 Stroke. Mine is a 2 Stroke, and needless to say, it burns fuel.
