Just replaced the rectifier with a brand new quicksilver brand one from the mercury dealer in a failed attempt to solve a non-operational tach issue. The new rectifier lasted about an hour or so out on the lake before something crapped out and the motor started sputtering and I had to nurse it back to the boat launch. Put in another new rectifier from the dealer. Rectifier looks like this one, small 3-wire unit.
Ran great on the muffs at home. Get it out at the lake and it runs nice at idle, bogs/sputter when I give it much throttle, will not plane. I pull the boat onto the trailer, disconnect the rectifier and tape up the two yellow wires and the one red wire, keeping them all seperate. Fire it up and she runs perfect out on the lake. Am I doing any harm running it like this? I drove it around like that for two hours, stopping and starting the motor a couple of times in there and didn't have an issue. Battery did not *seem* to be discharging during that use. I realize my battery won't be recharged by the motor without the rectifier hooked up but I'm tired of fighting with this thing. At this point having to top up the battery occasionally on the charger seems like a small price to pay to not have to keep fighting with this same issue.
The wiring diagram I have indicates if the rectifier is removed, the only contact the battery has with the motor is the starter. Without the rectifier/battery in the mix, will the stator put out too much voltage and eventually fry my switch boxes or coils??
