I own a 1990 Seaswirl Sable Cuddy with a Ford 351 V-8, 5.8L Cobra engine. I recently tuned the engine, and rebuilt the Holley 4Bbl carburator. Boat idles great and when on the water, cruises at 4500 rpm at 43 MPH. The problem I am having is that idle is fine, reverse in gear at low speed is fine, but while in gear in the forward gear at low speed the engine wants to die and shakes badly until you give it a little more throttle and then kicks in. I cannot figure it out and any help would be greatly appreciated. Thanks.
