Any idea where Tstat is on a 1990 200v6 'Rude
craigstuff72
I can't get water out the tell-tale and would like to know if there is a tstat to check? Is it possible to pull the heads off to check things out then throw em back on with same gaskets???I know its possible-----but---will the compression be shot to hell? thanks
Theoutdoorsman
Re: Any idea where Tstat is on a 1990 200v6 'Rude
Have you pondered the idea of a water pump? And yes.......you can pull the heads. But why? What makes you think you need to? BTW........welcome to iBoats!!!
Dhadley
The overboard indicator line is probably plugged, just blow back thru it. The t-stats will still work properly even if the line is plugged.
