any Ideas
Status
Not open for further replies.
puma1955
any idea on what happen here. i installed new engines
( volvo pentas 5.0FL 302 fords) . Boat ran great last week, cruising at 30 knots (3400 rpm) when port engine revs up to 6000 rpms.
i shut it down right away and did not get forward or reverse ( (VOLVO SX DRIVES) since then. It is not a spun prop changed that already. in forward i can spin the prop both cw and CCW in reverse I can spin the prop cw but not ccw, it locks.
When the boat rev'd up to 6000 rpm i heard no grinding or any other type of noise. I know the shifter is ok and the cable is connected. i also know that the spline output shaft is turning from the engine. the coupler is fine also.
any idea. someone stated it might be the cone clutch? or busted gear.
Don S
Re: any Ideas
Don't start 2 threads on the same problem.
This one is closed.
Status
