Any Info on Charger Boats and Battery Chargers
HI, Ive just purchase a 1999 Charger 375T Fish and Ski Any Info on boat will help, Any one have a Operators Manual and I think the boat had a Battery charger connected with a switch (Charge Back SW), The wiring diagram shows that, It Do not show brand of charger, will like to connect a 12/24V Trolling Motor Back up and go with an Aftermarket 3 bank Battery Charger (2 batts for TM and 1 batt for starting) The boat Have 4 6GA Wiring going from Battery Box to Bow where the (TM) would connect with 3 prone connector Any Info will Help
View attachment 177555View attachment 177556View attachment 177557
Re: Any Info on Charger Boats and Battery Chargers
sounds like you have a plug at the bow of the boat that a charger can be plugged into. this plug is proberly also used for the trolling motor and has a switch nearby that says something like 12vdc charge / 12vdc / 24vdc. this was a old school way to charge the trolling batteries and required you to remove the croc clips of a charger and fit a plug like the one on the trolling motor. if $160-$200 is with in your budget go with a 3 bank charger. if thats to much then buy a cheap charger and just install a trolling plug on the end (wire charger to 12vdc pins not the 24v dc pins). read the cautions that come with the boat as any miss-wiring creates smoke which is why no one likes to advise people to use the switch on a boat that may have been messed with (this will not recharge the starter battery).
