any info on rudy 33 please
robtherep
Hello<br /><br />Picked up another motor today. An Evinrude 33 horse SKI_TWIN can anyone help me with the following questions please?<br /><br />-does this motor have a good reputation?<br /><br />-what year is it?<br /><br />-does it have a generator?<br /><br />-is it known for speed, torque or lack of power?<br /><br />-it’s all white under the hood but the top cylinder is a bit discolored (yellow/brown) does this mean anything?<br /><br />-were they common with parts still easy to get?<br /><br /><br />Any info would be appreciated. Thank you very much!
Paul Moir
Re: any info on rudy 33 please
1) Yes. It is the reincarnation of the '57 (and some '58) 35hp engines with the stronger rods, crankshaft & bearings found in the '61- engines. However, it was an 'economy' outboard and does not have a thermostat or the "deluxe" sound deadening that went into the 40hp.<br /><br />2) We need the model number. Look up above between the two transom clamps, on the tilt/swivel bracket. Generally '65-'71<br /><br />3) That was optional. If it's there it's on the port side of the engine and connected to the flywheel via a toothed belt.<br /><br />4) That may indicate it's really a Johnson, and it overheated once. Since it's new to you, service the water pump.<br /><br />5) Yes, they all fit into the "Big Twin" classification - 25(50s),28,30,33,35,40hp engines '51-70something. Very popular and parts abound, cheap.
robtherep
Thank you Paul for all that info.<br />the mod. no. is 33752C ser. G516478<br />It also has a pull cord and electric starter. the ignition is seperate from the throtle and first goes to a box (screwed to the transom) then the motor.
Paul Moir
That sounds about right. That's a 1967 model you have there. I'm (very slowly) rebuilding a '65 now, so if you have any questions, just ask.
robtherep
Thanks guys<br /><br />That shareaproject site looks interesting. does it work well?
lark2004
yep, It's pretty easy to use too.
