Re: Any "Miracle" bilge cleaners known out there?
Fwiw, there are possible serious repercussions to cleaning your bilge and pumping the waste directly into water, either fresh or salt. It is going to be easier to clean the bilge if your boat is trailered because you can let whatever comes out of the bilge run down he driveway and work its way into the water system that way
To do the same thing while the boat is in the water can cost as much as $5000 fine plus any cost to clean up any hydrocarbon residue
although it all ends up in the same place as if you washed the bilge in the driveway.<br /><br />Simple Green is biodegradable
in most areas it is not an issue pumping out Simple Green out of the bilge directly into the water. It is considered gray waste. Just make sure it is ok to discharge gray waste in your area. Any gas/oil residue that is washed out by the Simple Green can get you in trouble. You should have a hydrocarbon filter on the discharge line of your bilge pump to separate any hydrocarbon residue from the wash water/Simple Green. You will likely need to replace the filter element after pumping the Simple Green through it.
