Any OMC coils that will work on a 2.2hp merc?
nola mike
I picked up an '89 merc 2.2 hp a couple of years ago, and have been trying to get it running right ever since. It's apparently made by tohatsu, and damn near everything is NLA. The points were on that list, so I replaced them with a Nova 2 ignition module. It ran great for a little bit, until it just died. The ignition system is magneto powered, but has an external coil. The way I understand it I get a pulsed low voltage signal from the magneto coil to the secondary coil, which has both primary and secondary windings. The coil has only one white wire in, the spark plug wire out, and is (i assume) grounded through the bolt holes. Resistance from the white wire to the bolt holes =0, from the spark plug lead to bolt holes = 5 ohms, and from spark plug to white wire = 5ohms. None of these values seems right.
Anyway, I think I need a new coil, but it's NLA. Wondering if an OMC coil would work. I don't know much about the OMC ignitions, but they don't seem as goofy as the mercs. What I think i need is:
External coil pack (ie, separate from the magneto)
From a magneto powered engine
CDI: I don't know if I could use a CDI coil or not. I'm guessing not, since the input voltage into the coil would be much higher. Are the CDI systems used exclusively with 12v, or are they magneto powered as well?
Oh, and single cylinder. Probably not an issue, since I'm guessing each cylinder has its own coil, but who knows.
raczekp1
Re: Any OMC coils that will work on a 2.2hp merc?
i had few johnson/evinrude/merc/tohatsu
its the same construction, all parts wil fit
nola mike
Could you be a little more specific? How bout a part # or a link?
raczekp1
ignition is the same mostly.
newer models tohatsu johnson evinrude shear the same parts, all have cdi ignition
older merc have points type ignition+ condenser+1 point,+i coil) but newer one has cdi also
so look at ebay if you are going to chane ignition mode
i think this Nova 2 is good solution
maybe you made short and Nova module fail
nola mike
I'm still getting 2 or so volts at the coil when I crank it, so I think the module's OK. Again, maybe you could point me to a specific coil that you think would work?
