Any one ever replace a lexan hatch cover?
dellsboater
I took my old cracked hatch glass (plastic) to the local glass shop and they made me a new one for 100 bucks. When I took the old one out of the frame, it just kind of pushed out. I know you use 3m 4000 adhesive to reinstall, but does it just sit in the frame? I did not have to remove any clips to get it out....
sasto
Re: Any one ever replace a lexan hatch cover?
My Bomar and Lumar hatches have been replaced, but according to factory I used polysulfied caulking I got from Boatlife.
dellsboater
Is this what you used? I see it does not list plastic?
.Life-Calk Sealant Tube 2.8 fl.oz.
Quick Overview
A long lasting, permanently flexible marine polysulfide sealant which can be sanded, painted***, and used above and below the waterline. Tack-free in 1 to 3 days, excellent resistance to teak oils, gasoline, and diesel fuel. Ideal for teak decks, to bed deck and hull hardware, seal thru-hull fittings, and underwater seams. Will bond to fiberglass, wood, metal, glass, and itself. Cures to a firm flexible rubber seal with excellent waterproofing and adhesion qualities. Can be applied underwater for emergency repairs. Can be applied to damp surfaces.
