Any place to buy new carbs?
mamm7215
Just wondering, I've rebuilt my carbs on my 90hp but the linkages and throttle shaft seem pretty loose so I was wondering if it's possible to buy new or nos carbs for these motors: 90hp '81 Johnson J90TLCIM
Thanks.
BigB9000
Re: Any place to buy new carbs?
0391712 0391712 CARB ASSY., Upper, 90. Not Available
0391719 0391719 CARB ASSY., Lower, 90. Not Available
It would be less $ just to replace the worn parts
mamm7215
so how would you replace the throttle shafts with cam plates? Can you just buy them separately? I'll check the BRP site...
mrcj001
I have two good used carbs off a 1975 Johnson 135.
Including linkage
Check around and see if they will fit the 90
PM me if you need them
