Windrider67
- Joined
- May 28, 2007
- 2
Hi, I'm new to the forum, and currently looking at a new aluminum in an 18'5 or bigger size. I like the Lund boats I've seen very much, more specifically, the 1950 Tyhee, and the 2000 Fisherman (both 2007 model year).
The trouble I'm having is that I find the driver's seating position to be very uncomfortable. Both units were equipped with the captain's chair option, but I also tried a "standard" seat in another model. In all cases, I found that:
1) I didn't have any leg room. There is a solid "wall" blocking the footwell. There is a speaker mounted in the wall. I don't need a speaker there nearly as much as I need a place to put my feet!
2) The seat was much too high relative to the position of the steering wheel. My knees were actually higher than the steering wheel itself when seated. The seat would was not able to adjust up or down to accomodate.
3) The seat was positioned too far away from the starboard gunwall -- my left leg was actually centered on the center aisle/console separation wall.
4) The mounting pole has what I would consider to be a lot of "play" in it. I expected a solid, secure attachment to the floor, but I found that every time I shifted my weight the seat would "rock" much like a dining room chair that isn't leveled properly. I can only imagine how much of a problem this would be if on the water.
Neither of the seats had the air ride option, nor was I able to try that because the dealer didn't have any boats equipped with it, so maybe that's better.
Now, I am 6'4" tall, and while that's obviously above average, it's not exactly rare. The Princecraft I tried on the same day easily accomodated my height. I'd like to hear from other Lund owners who are also tall. How is yours for fit? Are you comfortable? Or are all the Lunds basically the same.
