Anybody got a 1970-1972 60HP need fuel pump info please.
rayodunne
I discovered that the fuel pump that was sold to me is the wrong one and is only meant to be used on 2 cyl and smaller motors. The only difference I can see is the size of the supply nipple for the line to the carbs. It does however have a threaded nipple for this so I can replace with proper sizer nipple.
Has any one got a fuel pump from this motor and could they please measure the inside diameter of the supply nipple. This would help me out so much! Thanks.
Faztbullet
Re: Anybody got a 1970-1972 60HP need fuel pump info please.
The OEM # is 383765 but the following # will interchange 398385, 433390, 438559
rayodunne
Thanks for the part numbers but I am not able to return the pump as it is over a year since it was purchased. I am trying to make it work for the motor I have without spending another 90 bucks.
I know this is a old thread but do you still need that measurement?
rayodunne
Thanks for your reply
After some research I found it was 5/16"
