Anybody have stringers fail on them after replacing them using polyester resin?
madstories
I'm having a hard time deciding to use epoxy or polyester resin for the stringers on my f/g boat hull. I know that epoxy has a stronger bond on a repair, but its expensive. Has anybody ever had stringers repaired, or any other part, with polyester, and had it delaminate a few years down the road? Any real reason not to trust it?
tpenfield
I don't recall seeing anyone have trouble due to polyester. Poor workmanship would be the greater cause for a short-lived restoration.
If you use epoxy for the stringers, you will most likely need to stay with epoxy for the entire restoration. . . . the reason being is that the poly will not adhere to the epoxy because of the amine blush that usually remains on the epoxy surface.
poly is fine, you just have to grind the old stuff to prepare the surface. (you still have to grind the old stuff with epoxy)
ondarvr
Has anybody......yes.....with both types of resin. You at least need to do an adequate job for it to last.
sphelps
Clean glass with fresh poly no problems ...Good wipe down with acetone before new glass ...
Woodonglass
All the EEEEEEEpoxy guys will tell you that the Poly will absorb water and delaminate. All the Poly guys will say " Bull#*!*" Each of them have pro's and con's I LIKE poly and have never had any of my laminations De-Laminate.
Baylinerchuck
Trust the experts above they know what they speak. I'll just add that boats are constructed using polyester resin. Boats rot from the bottom up prematurely from poor upkeep. A properly performed restoration will last decades as long as the boat is properly cared for.
madstories
Thanks everybody. Im much more comfortable with proceeding. I guess I read too much crap from companies trying to sell epoxy.
