elkhunter338
- Joined
- Jun 27, 2009
- 818
A common problem that is surfacing with alum. boat moored in salt water is the cheap china plugs go bad. There is not much threads, most are brass of some sort and the brass dissolves over time thus the plug fails and the boat sinks.
North River Sinks Due to Corroded Plug - www.ifish.net
My buddy installed a new plug this summer and within 2 months the plug went bad and started leaking, luckily he notices his bilge running more often and got he boat on the trailer to find his quote new plug the threads were gone.
So has anyone converted their boat to a pipe threaded plug? All you need an alum. pipe plug.
It appears you could tap the hole for a 3/4 pipe plug but I am not sure the wall thickness on the plug hole is adequate after being threaded. I measured the hole and 3/4 pipe plug and It measured the wall thickness would be 0.15 which seems too thin.
I do not want to weld on the boat and heat up the seam and cause a leaking issue. You could weld the hold closed with an alum. slug, then tap it for 1/2 pipe plug.
