Anyone had damage from E10 gas in Mercruiser?
isaksp00
I use non ethanol gas in my 8HP outboard and small engines at home. Just bought a 19 footer with a 6 cyl fuel injected Mercruiser with Alpha drive. So far I have been buying non ethanol gas (at $3.85) at a local station and pumping it into the tank 5 gals at a time. The on-water price is $4.65 for the E0, so I avoid that. My question: there are a lot of opinions about whether ethanol gas is bad for inboard fuel injected engines like the Mercruiser. Does anyone have experience where say there actually was damage or problems? I could save almost $1/gallon if I go to the E10 from the roadside stations.
fuel up with e0 or e10..... and go boating
your stressing about nothing as long as you dont let the boat sit.
E10 goes bad long before E0. so go boating often and you wont have a problem
GA_Boater
Use the E10 and use the boat. At the end of the season fill it up and add some fuel conditioner if you want.
Most importantly is use the boat!
briangcc
I run E0 exclusively after having a fuel pump crap out and filter debris from running E10 in my Four Winns.
harringtondav
My only problem w/E10 was vapor lock or alcohol boiling on a very hot day. 4.3LX 4bbl Weber. 30 seconds of idling fixed it I've heard FI Mercs have a fuel cooler, so you should be good.
thumpar
I run E10 and even let it sit all winter with no issues. I did it in the 1983 carbed boat and the newer EFI boat.
Oshkosh1
Ensign
It's the ONLY fuel I run in EVERYTHING. My boats, cars, trucks, lawn tractors, snowmobiles, ATV's, chainsaws...whatever. IF it takes gasoline, it's getting E-10. My boat sits with it in the tank all winter and fires right up not missing a beat come spring. I also store a couple of vintage cars and again...never miss a beat come spring even if only filled 1/2 way. I found a gas can last weekend up at my other house and know it's at least 2 years old but filled up my lawn tractor and cut the grass. Run it without hesitation...
achris
More fish than mountain goat
An advantage of E10 is that it holds water, so a small amount of water entering the tank, in the air through the vent as fuel is used, will not accumulate in the bottom and eventually lead to 'water in the fuel' problems. It just gets carried through the fuel system and burnt as part of the fuel load.... :D
Chris........
Grub54891
I also run e10 no issues. But in the last run of the season I run e0. Just because.....
Lou C
Here we have no choice, it is all that is available due to the draconian EPA. I don't think E10 is a problem per se but the issue is the accuracy of the mixing in the gas tanker truck. If you get a load of e15 or e20 that's when the trouble could start. Plus, many people never inspect the gas cap gasket and that can let water in, not a bad idea to change the cap every 2/3 seasons.
