**anyone have a diagram for 81 115 evinrude recirculation hose routing?
x69_x69
:confused:it seems there are four on each of the cylinder sides and 2 check valves on carb. side?
Daviet
Re: **anyone have a diagram for 81 115 evinrude recirculation hose routing?
Can't quite figure out what hoses you are talking about. Can you post your model number and a better description of where the hoses start and end?
jonesg
There is one hose for each cylinder, 2 on each side of the block. Total of four.
They feed opposite cylinders, thats to say top carb feeds bottom cyl, bottom carb goes to top cyl.
x69_x69
the welsh plug says E115WLCIM 0001272 what the deal is i was suppose to have purchased a 1976 135 hp johnson w/tilt&trim
much $ later come to find out i have a what i think is a 1980 115 hp evinrude power head on a 1976 lower end and 1976 carburaters it has fair compression (even on all 4) and ran great when i went to buy it (bench tested)but having to replace all hoses im going up there today (storage) ill try and take some pics thank you guys for your assist i think by the time im done with this project i will know more about outboards than i wanted too, lol
edfishing2
The recirculation on mine (84 100hp) has 4 brass check valves on the manifold that are under the carbs. These go to a 5 way black plastic Tee and number 5 line goes to the block to lube a bearing. Please save yourself some trouble and lube this 1/16 ID hose before you try to install on the black plastic Tee. I broke mine.
x69_x69
i have pics Picture 138.jpgPicture 134.jpgPicture 148.jpg were does primer sol. go?:eek:
edfishing2
Your manifold looks like mine. On the last photo these are the check valves all 4 of these go to a 5 way Tee and the extra hose goes to the block. Your first photo showing the bypass covers is not like mine. Look at your 2nd photo see the nipple/barbed fitting right below the throttle arm. That is where mine has the 5th hose going.
