Anyone know what these are called?
DanD34
Does anyone know what these wire connectors are called? Need to get a couple but cant find online. I'm sure if I had the proper name I could hopefully find. It is in the remote control handle for my 1988 Alpha 1 Gen 1 3.0 and connects the trim switch to the wiring harness. These then snap in to the protective cover so really need one of these connectors unless I want to cobble. Which I don't. Thank you.
Ayuh,..... Looks like bullet connectors to me,.....
andrewterri
Have you tried looking up the parts catalog and seeing if its listed? It will have a part number and you can google to find it that way. I do not know what brand controller you have but they will have a parts catalog listed somewhere.
DanD34
They are not a separate part. They are part of the switch on one end and wiring harness on the other.
Lift12
Those are broadly called Pin and Sleeve terminals. There are thousands of varieties. I would search the big electronics wholesalers i.e. Digi Key, Mouser Electronics. It will help you narrow your search to know the dimensions fairly precisely, in millimeters.
