Anyone use any battery conditioning products?
Just watched an episode of Ship Shape, and the show was about a battery conditioner product by Inox. It was in a small blue bottle, and the actual product was Inox-mx2. Website is here: http://www.inoxlube.com/
The company rep stated it guaranteed battery life to be between 6 and 10 years if the product is used in a new battery.:confused:
And will extend the life of an older battery.
I just bought 2-new batteries and would love to get 6-10 years out of em.:D Doesn't seem to make it to a third of that the way I've been doin it.
Anyone have any experience with any products like this or this actual brand?
Boatist
Re: Anyone use any battery conditioning products?
Battery life is more how a battery was maintanied than brand or type.
First if it a flooded battery keep the battery water level at the proper height and only use distilled water.
Second all batteries self discharge.
They self discharge faster in hot weather so in summer must fully charge every month.
In cold weather every 2 months is good.
I always say most batteries dont die they are killed by onwers.
Example take the boat out Saturday for some fishing and a trip to the beach.
Use the trolling motor on your deep cycle and run it down 60 percent.
The starting battery runs the boat motor, blowers, lights, radio, GPS, Depth Finder and tilt and trim motors.
So you fish in the morning then stop at the beach for lunch and swimming and some tunes then take a 10 minute ride back to the launch and put it on the trailer.
When you get home your hot and tired so do not do anything to the batteries.
On Friday or a couple of week later you decide to go again so you charge the batteries the day before.
Leaving batteries discharged like this will shorten their life a lot.
When a battery is discharge the damage starts to happen and the longer it discharged the more damage is done.
A discharged battery will have a different chemical ballance than a fully charge battery.
I have always fully charged my batteries with a good automatic charger as soon as I get home. I have not had a battery that did not last at least 6 years and my deep cycle may be over 12 years old. I got it back when Price Club sold Delco deep cycle battery. This was long before they changed the name to Cosco.
Another thing is a starting battery should not be discharged more than 20 percent and a deep cycle should not be discharged more than 50 percent.
So in my opinion is the best way to make your batteries last a long time is to make them easy to fully charge and do it right after every trip.
On my boat I installed a pulg at the bow of the boat that I can hook a battery charger to. When I get home we back the boat into back yard and I go inside and bring out the charger and plug it in. We then unload the boat and clean the fish.
At this point we cover the boat and I check the charger to see if the batteries are fully charged. Most of the time mine are fully charged long before we get done with the other chores.
My boat batteries are charged by my I/O with a 65 amp alternator thru a battery isolator. I can also charge while going down the road from my trucks 100 amp alternator by pluging the boat into the trucks 8 guage 12 volt line to the trailer.
I Only do this when we bait fish till about midnight then make the short run back to the ramp for a 1 hour trip home.
There are some thing you can put in batteries but in my opinion all they really do is make money for the seller. You can empty out all the acid from the battery and refill with the new battery acid. While this works fine if you care for your batteries it should not be needed.
One other thing that I do is I dont charge the batteries when the batteries are very hot.
My boat sit out in the hot sun with a dark blue Sunbrella cover and reaches 140
degrees inside allmost every day in summer.
I do not charge batteries when over 80 degrees inside.
I believe the key is to get a good automatic or smart charger that will fully charge without over charging.
This could be a onboard charger, or a portable charger.
Make it very easy to hook up and charge so you do not have to uncover the boat
and clime inside and hook up batteries to the charger.
When it simple and easy or automatic you will charge more often and increase the life of your batteries.
robert graham
Sounds like snake-oil/hogwash to me. Keep your battery with a full charge and keep your terminals clean, should be fine for 3 or 4 years. But you know a battery can show up dead or a weak cell pretty much whenever it takes a notion. I like an overnight 2 amp charge the night before departure. And keep your grandchildren out of the boat the night before, because they LOVE to turn on switches and buttons that can kill a battery! Good Luck!
bruceb58
Contains cadmium sulphate which people sometimes dump into batteries that have gotten sulfated. If you let your batteries get that bad, save your money and apply it to getting a new battery.
Thanks for the replies guys. So the reason a battery will buildup sulfate is due to large draws on the battery without being charged fully, then using the battery again in the same manner never getting the battery charged fully?
Just curious.
Eric
bruceb58
Leaving the battery for a long time while it is not fully charged will cause it to sulfate. Has nothing to do with how fast the draw was that got it down to its discharged condition. Just the fact that it is discharged.
itsrusty2
I purchased the 1 liter bottle from http://inoxbattery.com/ The batteries do seem to have a better starting power than before. They also said they would grantee the batter a year past the warranty if it is put in a new batter.
Well see
bruceb58
Well see
Its possible it might help temporarily if you let your battery sulfite up. There has to be a drawback of putting that stuff in there since you basically diluted your electrolyte.
itsrusty2
I agree, seems odd. I found this on their website,
A: Yes, INOX-mx2 will work on your older batteries as long as they are still mechanically sound. It can be added to a battery at any age, however, the older a battery is, the less effective INOX-mx2 will be. If an older battery will not hold its charge properly, has recharging problems, or is just generally slow, the addition of INOX-mx2 in 97% of the cases will give the battery an additional new life of up to 2-3 years. A battery may seem mechanically sound, but could collapse very quickly through some undetected fault in the plates or separators after the addtion of INOX-mx2. This only accounts for a very small percentage of older batteries treated. Most solar charging systems have low ampere charge rates, the addition of INOX-mx2 to these batteries is good protection against the build up of sulfation, giving them better long term life.
