Re: anyone use toyota tacoma to tow ?
I'm easier going than some of the guys on the board when it comes to towing. But unless you are driving a matter of yards to a boat ramp, there is no way you will be able to tow that. I feel the most a good four cylinder can handle is around 2,200 lbs, in town. You will need at least a 3.5 liter or larger V6 with at least 200 h.p. to begin to tow a 21 ft. boat.<br /><br />Your boat and trailer probably weigh more than 4,000 lbs. <br /><br />First gear achieves a whole lot of torque, even if you have a four cylinder engine. On a boat ramp, you may be able to go up at only 3 mph, but the car can easily do it from the torque provided from first gear. You would be surprised.<br /><br />The problem occurs when you want to go faster.
