Appleo's 1985 Starcraft Supersport 18 foot - Restoration 2019/2020
appleo
Picked up this 1985 18 foot beauty on Clist.. Finally got around to getting started ....I was able to finish gutting before the snows arrived........Been in the hangar for almost a month ..working as fast as i can to get ready for spring panfishing!
Progress photos to follow !
Cheers!
appleo
The "gutting" of the beast commenced with assistance from a neighbor student .... at a burden rate of 10.00 per hour.... well worth it to get the progress moving !!!
Used what I could from the rotted woods for templates..........alot of trim pieces had gone missing
Nasty!
Foam was tested with cross-sections and found dry and will not need to be be replaced
Motors removed and sold for parts on Clist
Hull has minor dings . Baby Blue Starcraft paint severely weathered from sitting in the prior owners back yard
Steering cable amazingly loose and functional
appleo
Decided to attempt to rub out that weathered hull to see if it would come to life.
TIP: Megulars Ultracut from Harbor Freight
appleo
Before and after. .......
appleo
A lot of gunwale rash. Any ideas how to clean up?
appleo
Twin bilge pumps installed. One controlled from starting battery at dash panel. Other redundant hooked to trolling battery via internal float switch and fused
oldrem
I started with Alumiweld but got too much warp from the heat. I then used Marine-Tex to finish which would have been paintable after sanding.. Then I decided to cover it all with Nautolex anyway.
appleo
Sidewalls covered with 22oz marine carpet grey. No need to remove prior glue.Just sand any high spots
Weldwood Contact Cement Original formula used
Floor panels started to be laid
Ribs marked on sidewall with distance to center braces
5/8 Advantec flooring with 3 coats spar poly.
Nautolex Floor covering Shark color
Weldwood again
Stainless screws from Albany fasteners
appleo
Old floor had ski locker. I am not a fan of those as they collect water and not dry. Old hatch plastic was warped and bad. So instead i filled under the floor with additional flotation closed cell foam.
Ran a spare hose and some 12 gauge 3 conductor wire from stern to bow
appleo
Nautolex main floor is done. Used a gallon of the Weldwoo contact cement
Good thing I have a detached garage. Stuff really stinks
Decide to now tackle the gunwale rash and the bow area.
Need to remove all snap buttons, patch holes , remove pitted cleats, remove black rubber mat glued to the bow. What a mess..
appleo
Pita
appleo
Bow patched with bondo Sanded and prepped.
Coated with Intetlux Seattle Gray. with inter grip poly beads mixed in for antiskid
Dollar tree mini sponge rollers
Two coats 24 hours apart
appleo
Some of the heavy damaged gunwales sections were hard to cleanup perfectly with Bondo and Anti-skid paint
Made some 7" x 3" "rash covers" from nylon cutting boards i picked up at Walmart for 88 cents
Shaped and Trimmed them on the band-saw ...2 covers from 1 nylon cutting board
Placed under the cleats and bow rails
New Sea-sense horn was installed with a bamboo cutting board piece I picked up at Dollar Tree for a buck and spar varnished
oldrem
Neat idea
appleo
Today was bow rails day ,
Original Starcraft boat had no bow rails
I like bowrails. To help keep the captain from
going overboard when he's fishing up front and one of those speedboats zooms by with s 4 foot wake
Found these rails at garage sale for 18 bucks. trimmed them with grinder. drilled and tapped screw holes as this stuff is harder than self tapping screws
Had a few gripper cleats found in the barn i added for light duty roped up front
Used a backer plate under the gunwale to make it sturdy.
appleo
Thought about ice fishing today but couldn't get a partner
Decided to install the trolling motor bow plate.
Made a few support plates for underneath with Advantec scraps and coated them 3x with spar varnish
Topside I had some mahogany kitchen table pieces from a prior restoration. Used them under the Minn kota power drive mounting plate .
Stainless bolts 1/4-20 I salvaged during tear down
I have three old Minnkota bow mount power drives V1 i bought and repaired years ago So I can swap them between boats
Someday the pedals will crap out and since replacements are not available I will have to repower
appleo
Rear side panels fanned and being installed
Had no templates so I built then from info from other starcraft owners
3/8 plywood with spar varnish
3/8 foam attached with spray weldwood contact cement
Grey marine vinyl from Joanne's Fabris. look for the40% coupon online
Stainless staples for hand staple gun t-50 arrow
Prior owner left some speakers in the boats. they were still good so i reused them and added new grilles
