Re: Appling pinstriping
I'v seen several ways to position tape. You can follow the countures of the hull, following small marks set by measuring from an edge, rubrail or so. If you want stripe to follow waterline, level boat on trailer so waterline is parallel to ground, on a straight surface. Build a little stand, with a pencil sitting on a horizontal bar of appropriate length. Now use pencil to mark buttom of stripe, same distance from ground. Place stripe along marks, you can now position correct undependable of curves and chine of hull.
