diesel1960
- Joined
- Jul 3, 2012
- 205
Just wonder how many people still using this ancient engine ?
Right, they are Volvo B30 6cyls. Volvo only ran them from '68-'75, so it is a fairly limited production run but plenty remain because of Boats/car production combined.
I'm shining up the AQ170 for my 17 footer. Haven't had the boat in the water yet, bought it as a project. The engine has been started a few times after I bought it, compression is decent and equal on all cylinders. It is fresh water cooled.
If it wasn't fresh water cooled, I had probably thrown it out and replaced it with a VW diesel.
I am proud owner of this inline 6 ,attached few pics before and after :
View attachment 175973View attachment 175974View attachment 175975View attachment 175976
But it will take some custom work, cause there are no companies that makes any adaptorplates for connecting a VW engine to a Volvo outdrive.
I am VW enthusiast-can we fit 4cyl.diesel to AQ280 outdrive ?
That.... Plus you are not going to find a marine exhaust manifold for that engine, or at least one that may work with a Volvo drive. It gets even worse if the diesel you're thinking of is a turbo diesel.
Actually, these days there is a manifold for sale for this engine on Ebay
MARINE 6 CYL VW+VOLVO 2.4 DIESEL EXHAUST MANIFOLD MARINE ALUMINUM WATER COOLED | eBay
I know it's a "one hit wonder" and there will probably never be one for sale again, since the manufacturer doesn't exists anymore, AFAIK.
Looks great!
I can see that you have vaccum advance on your distributor, I don't have that on mine.....
The cooling system on my engine is called "MARTEC", maybe only sold in Europe, I don't know. This kit is made specially for the B30 engine, with brackets and plumbing. But I have modified it, since there was not enough space in my engine compartment for the original placement of the heat exchanger. The brackets included in the kit, are ment to be bolted onto the Starbord side of the engine.
I was actually thinking about installing a straight-6 VW diesel, instead of the B30, in case it was dead. You may have seen that engine in the US, it was installed in the diesel version of the Volvo 240 car in the 1980's.
