AQ Transom shield exhaust relief single to double?
Ciera2450
Hi everyone! I am redoing my transom currently and have my drive and shield off for the job. I have known for a while that the shield had a small hole drilled (maybe 1/4”-3/8”)for one of the exhaust relief. Not done by me! Is there any reason I can’t do a proper job and drill the hole properly to match the other side? This would essentially make a v8 shield? Am I missing something else? The hole is obviously supposed to be much larger and the inside edge has a small lip. I can post pics later.
ive owned the boat 7 yrs and ran it this whole time time as is with no issues. Aside from the one little rubber hose breaking off the one side that had the proper factory exhaust relief. Can those hoses be had still? I’ll need two if I’m able to replicate the proper hole.
thanks for any advice!
Ciera2450
I will get pics of the shield and y pipe later today to illustrate what I’m talking about. I’d like to fix it while it’s all apart and removed from the boat.
Ciera2450
Well, looks there are more differences between the 4cyl and V8 shield. The holes aren’t in the same location vertically compared to the ypipe.
Heres pics. I’m thinking it still may be possible to have it machined for the proper hole locations and fill weld the misaligned hole. Any thoughts?
this is the misalignment with he y pipe
AD70B868-08EE-4BCD-AFD3-7659F5040BE9 by Ciera 2450, on Flickr
othr pics of the drilled hole someone added and also parts numbers
650A8AA1-86E2-4407-B081-7ED7F78FEDBD by Ciera 2450, on Flickr
CEE5214C-79BC-4D92-88B8-C8041FB7CADD by Ciera 2450, on Flickr
08151A9B-B8A0-496D-8DAB-DE764BD2F046 by Ciera 2450, on Flickr
shield part #
8ACB36B5-14A5-44FC-A8B7-603521BD64EF by Ciera 2450, on Flickr
you will need to counter-bore the hole, however what are you trying to gain? the idle relief ports are simply there to prevent water from backing up the exhaust. most goes out the drive
Ciera2450
Thanks for the reply Scott! So I’d be ok to just run as is? (I have for the many years.) How would I got about sealing y pipe to shield properly? They just Gobbed sealant in this area.
Ciera2450
My line of thinking was that I’ve got it apart, fix it right.
You seal it with the correct rubber tube
The changed the design.late (maybe in 1986), where the idle relief ports are solely in the Y-pipe outlet
Ciera2450
Can you clarify Scott? Should I just buy the one “proper” side exaust hose and oring the other side?
look at the parts diagram
http://www.volvopentastore.com/Conn...on_id.742058223--store_id.366--view_id.776337
I believe item 23
Ciera2450
Thank you sir! Getting closer to reinstall and will probably have more questions.
