AQ120B Alternator specs?
Handegard
I wanted to have my alternator bench tested and possibly rebuilt, but I need to know the output specs.
Basically, the local rebuilder charges to test if you aren't having him do the rebuild. I want to test before I commit to a rebuild. CSK will test it, but you have to put the specs into the machine first I guess.
Oh, and in case there was more than one, mine is a SEV Marchal.
I believe I found it. I forgot I have two manuals. Is 38 Amps right? That seems very low to me, but I guess it doesn't run much on the boat does it?
I will try and get it tested tomorow.
Thanks anyways ;)
dgabler
Re: AQ120B Alternator specs?
According to pub no 3267 dec 1976 it it a 38A alternator.
Handegard
Anyone know if there is a replacement model available?
My rebuilder says some of the parts he needs aren't available anymore. He has enough to do one more, but after that he can't do everything.
