Once it?s warmed up it runs fine at idle. After five minutes of running or so it does not want to idle. It will typically start back up at run for 5 seconds or so and then start to die. Even giving full throttle does not keep it running.
I attached an external outboard type fuel tank directly to the fuel pump and got the same results. I have also checked the fuel screen in the fuel pump and it is clean.
So, I?m thinking I should rebuild the carb. Any one know where to get a kit? I believe that it is a Solex 44 PHN 3.
Thanks, as always.
Thanks, as always.
